Ran my tire pressure up to 50 psi
#11
That is good to know. Thanks
#12
Originally Posted by SYMAWD
They are set high for when they are transported from the factory. The dealer should have set the correct pressures during PDI.
Also normal pressure is 32 front 32 rear for the Q7. For max load it is 32 front 35 rear.
EDIT: I see you edited your post.
#15
You reference WEIGHT above. I am adding 700 lbs tonque weight to the rear tires.
Should I increase tire pressure to compensate?
#16
It's dangerous to run 50psi on a car supposed to run 32psi.
Handling would be abysmal. Far less responsive and less grip in an emergency situation. A blowout is also more likely.
Also with motion the tires will get warmer and the pressure will further increase.
#17
First: max inflation pressure is with COLD tires; it is NOT the max operating pressure.
2nd: it is the max pressure the manufacturer recommend.
3rd: it is also the (cold, inflation) pressure the manufacturer makes the max load carrying statement for. If you don't inflate to that pressure and run the max specified load on the tire, THEN you run the risk of blowing up the tire.
#18
The driver's door placard on my 2019 Prestige specifies the following tire pressures: 38 psi front/41 psi rear. However, my owner's manual shows tire pressures for two load conditions: for 2 passengers - 32 psi front/32 psi rear, and fully loaded - 38 psi front/41psi rear. I routinely drive with another passenger, a couple of dogs and a bunch of gear in the wayback. Any suggestions for a happy medium set of tire pressures between the 2 extremes in my owner's manual?
@mhoran89 I went back and looked at when I scaled my Q7/Boat combo last spring. Here's the weight change with the boat. Rear axle picks up 460lbs, and the front loses 120lbs. In retrospect, I probably don't need the extra tire pressure for towing. This was with 1/2 tank of fuel and just the wife and I in the car. Full tank of fuel, 2 boys, a dog, adn a weekends worth of camping gear probably swings this heavier.
mhoran89 (05-26-2022)
Regenmeister
10
07-14-2005 03:34 AM
UrSoccer_mobileĀ®
11-19-2003 08:02 AM
