S-Line Flat Bottom Steering Wheel
#11
Why stop at s line...europrice have the flat bottom sq7 steering wheel
It's amazing that Audi cannot design a steering wheel with flat bottom and heated.
#13
Bumping this thread up ... i am about to order from EuroPrice and want to make sure it is a direct replacement... My Audi dealer wanted $495 to install, but my local Audi/german/exotic independent shop with a great reputation said they would do it for $175. It looks pretty simple based on that youtube video... i just wanted to see if anyone has actually done this mod yet.
Or is there a better Audi tiller that is a direct bolt-on now?? Want a thick and flat bottom model.
Thanks in advance!
dave
Thanks in advance!
dave
#16
Thanks in advance!
dave
Thanks in advance!
dave
#18
I have replaced a Mini steering wheel and a BMW X5 steering wheel. It's not difficult, it just takes patience. I cannot stress enough how important it is to disconnect the battery. You don't want to screw around with the airbag, which is essentially a small explosive that can do significant damage, especially if your face is right in front of it while trying to remove it from the wheel. On both the BMW & the Mini, I had to use 2 screwdrivers to move a metal catch on each side to release the airbag. That took great patience. It also takes courage, as you are going to put small holes into the back side of the steering wheel (assuming the Q7 process is the same as my experience). It was difficult to break the seal on the bolt holding the X5 wheel onto the car. That also too great patience. The Mini was quite easy. All told, this is a relatively easy mod as long as you take your time. I'd set aside 60-90 minutes. Good luck!
#19
OK, just watched the video above (note to self, do that next time prior to posting a reply) and this looks relatively easy compared to my experience above. Using a phone as a mirror and to document the procedure so you put things back together the same way is a great pro tip!
