Second row rattle / vibration sound
Anyone here had any luck with this problem? In the Poll thread, there are a couple owners having this same issue. It'll be very helpful to share if someone actually got it fixed. Thanks in advance!
Originally Posted by Keyser Wi
(Post 24948835)
(Post 24948835)
By chance, I was raising the 3rd row today and noticed that the outer seat belt connectors make this very sound when you move them. Sounds like the anchor point needs some grease as it's a metal on metal sound. |
(Post 24948835)
I have a rattle that's coming from the back of the vehicle. I've found that it's from the cargo cover. It seems that the unit starts to ride up out of the retaining mechanism with use.
I'm getting my Summer tires put back on on Friday and will have the dealer look at it. |
Originally Posted by Lookout57
(Post 24951082)
Originally Posted by srbsq7
(Post 24950221)
I sometimes hear a high pitched rattle (almost squeaking sound). Not sure if this is the same issue?
Originally Posted by Jeffrey Lembang
(Post 24955241)
I fixed this squeaking by applying electrical tape on the floor latch on the floor of the second row seats. Also greased the locking mechanism attached to the seats for good measure. My squeaking is now completely gone. Hope this helps! =D
I think I know what he means. It's the latches where the folded 2nd row seat latched to when in used. My issue is not squeaking, but soft rattling. In any case, I will check the 2nd row folding & unfolding mechanism again and see if I can find a possible cause.
I have a rattle in the second row and I found it to be the drivers side seatbelt hitting the side plastic molding when not being used. I have yet to find a way to make it stop hitting when driving and not being used.
