In service
Old 03-25-2019, 09:42 AM
  #21
BigKutta's Avatar
Originally Posted by JT4
I'm assuming your Q7 has runflats, and did the Q5 have runflats or traditional tires?
Our Q7 has runflats and my Allroad has traditional tires, and while the Q is in another level in regards to refinement and being quiet the allroad absorbs bumps and road imperfections much better. IMO it has to do with those horrible runflats..
Frankly, I didnt bother to look. It rained the whole time I had it, so didnt bother to check anything about it
Old 03-25-2019, 09:47 AM
  #22
mhoran89's Avatar
Received 1,158 Likes on 906 Posts
mine has runflats but am waiting another week or so to take snows off. i am not thrilled to go to runflats - i will most likely try a 275/45/20 non runflat when these burn up which is not soon enough
Old 03-25-2019, 11:13 AM
  #23
ConservativeConsumer's Avatar
Sorry for jumping in... Are you thinking about what I am thinking about:
https://www.tirerack.com/tires/tires...omCompare1=yes
or something different? Thanks!
Old 03-25-2019, 12:10 PM
  #24
mhoran89's Avatar
i would be inclined to try this first... i don't need an "ultra high performance" tire on a 3-row SUV.
a touring tire should be quieter, smoother, and better wear characteristics (especially on a heavy car).
Old 03-25-2019, 12:56 PM
  #25
BigKutta's Avatar
Arent these the OEM 20s?
Old 03-25-2019, 01:54 PM
  #26
Sorry, the link above somehow got mixed up. I am thinking about DWS6 275/45-R20 tires. Though Pirelly linked are not OEM as they are non-runflats and of different size.
Old 03-26-2019, 05:28 AM
  #27
mhoran89's Avatar
The pirelli 285/45/20 runflats are more money, worse ride, 520 treadwear vs 740 on those non-runflat pirelli 275/45/20. the 275/40/20 pirelli non-runflat has a higher speed rating too (better handling / heat shedding ability), and marginally less load rating so it will only matter if you are carrying bricks around or are towing thousands of pounds... Carry a large size can of flx-a-flat in the trunk and end of story.
right now i have goodyear 285/45/20 runflats (https://www.tirerack.com/tires/tires...omCompare1=yes) and they are heavy as all hell... i cannot see a reason to spend $100 more a tire for less treadwear and a worse ride...
but at the end of the day i understand if peace of mind is what you are after then by all means go with a runflat.
Old 03-26-2019, 05:35 AM
  #28
mhoran89's Avatar
Size is irrelevant you are within 1.5% overall in diameter and rolling circumference. No one is going to notice the 0.4" height difference between the two. and differences in alignment will be negligible.
The Continental DWS06 is a great tire, been around forever. Rides compliant and smooth, but can get a tad noisy when it starts to get low on tread.
Bigger issue is because it is a "ultra high performance" based tire. It is going to stick like glue for an all season but you will not see many miles out of it compared to a touring tire.
I would be surprised, even with regular rotations, to see anything more than 35K miles out of a set of 4 on a heavy SUV like the Q7... but YMMV
CH
07-23-1999 08:39 AM
CH
07-23-1999 07:34 AM
JT
02-10-1999 06:22 PM
Kevin Y
12-13-1998 03:05 PM
Quick Reply: In service
