Is there a trick to getting the rear hatch open with foot swing
#11
You gotta find the right spot. I have the two package, so left of the hitch does the trick. The other piece is patience. It takes a second or two after your motion before it acknowledges your motion and then opens or closes the hatch. One motion. Wait for the beep.
#12
I've noticed this too... There is a slight delay before you hear the latch disengage and the hatch begins to open..
#13
I think all of this just highlights the flaws of this feature. It's supposed to make opening the trunk easier, which to me means not being so sensitive on how fast you kick, where you kick, etc. They should put a laser dot on the ground, let you put your foot on the dot and have that release the trunk.
Stephen Thomson (03-18-2020)
#14
#15
#16
I know how to use the feature and it simply doesn't work as consistently for me as I like, probably because I only rarely use it. I have 1000 other things in life to worry about aside from regulating the speed, angle, and location of my kicking.
#17
I used to hate it until I properly learned how to use it now it works every time without fail. My mistake was that I wasn't patient enough for it and I kicked again.
#18
In the time it took you to write these posts you could learn it. Its pretty easy and works every time
#19
To be crystal clear, I have read the posts, I have seen the video, I do kick straight, I do kick slowly, and no, my hatch doesn't open 100% of the time when I kick. I'm not technologically inept, as I am typing right now on a computer I assembled by hand. I fully will acknowledge that I'm not a football punter.
Some days the hatch works consistently, some days it doesn’t. The fact that my Q7 sits in a garage for a few days a week may cause it to go into a low power state that deactivates the hatch. I'm not sure, and the function isn't important enough for me to bring my Q7 to the dealer.
I think a board is useful because it highlights different perspectives. Mine is that the system should be more reliable, that's all.
