Towing package, now what?
I got the towing package when I ordered my car a year ago. I didn't get anything else. I'm looking to get a hitch carrier for a trip (cheaper than roof bars and enclosure) and was thinking of putting some brake lights incase it covers the cars. I have no idea what else I need to buy to get the connector in the back.
I see two things on this page that seem like what I need.
https://parts.audiusa.com/accessorie...Tow-Hitch.html
Like if I wanted to use something like this.
I think a lot of trailers use this type of connector incase I needed to two something else.
https://www.amazon.com/Nilight-Tailgate-Flexible-Taillight-Vehicle%EF%BC%8C2/dp/B07F1PWDP2?pf_rd_p=3ebd7bb8-e4db-4762-b094-2aa45768a3b5&pd_rd_wg=0y9Mi&pf_rd_r=4FRZ0D7KX2KDRNNTBDN8&ref_=pd_gw_cr_cartx&pd_rd_w=ciw5q&pd_rd_r=03bd651a-abbd-4be0-9472-8fa34fb22f54
https://www.amazon.com/Nilight-Tailg...2-8fa34fb22f54
You will likely also need the actual 7-way socket. That is not automatically included in the tow package. The Audi version is $75. This is identical in fit: There will be a spot just to the driver's side of the hitch receiver for the socket. If you already have a socket there, then you don't need my link. If you have a bare metal plate there, the wiring harness that should be tucked up behind the bracket and plate will plug into the socket linked above and the socket will screw in to the bracket instead of the metal plate (use the plate screws to install). Those sockets can be found locally at RV stores as well. The 1st one I received was defective, but I think it was a fluke.
Yea I just went out and looked. I do need that socket that Albert posted. Right now it's just some wires going to a flat plate with four screws. I tried taking it off and removing that blank plate, but I can't figure out how. There was a red plastic tab that I removed and still couldn't get the wires free. I've never dealt with trailers before with as much car wiring I've done in my life (audio/security).
I installed the plug in October 2017 and don't remember all the details, but I had posted this afterwards in a different thread: "2 points of interest: the Audi end of the wiring that plugs into the Pollak 7-pin connector has a red tab that locks into the connector. That tab locks it onto the flat plate cover that comes on the car as well... So when you unscrew the plate, you need to look near the rear of the plug and find the tab, which extends to unlock. You must FULLY extend it to release, so if you think you did that but can't separate the parts, it means you didn't extend it enough! #2. The particular Pollak plug I received turned out to be defective. The connection to the left taillights/brakes for the trailer was not good. Replaced with a new Pollak plug I bought locally and it worked fine. Random bad plug, but be sure you test it before you REALLY need it. Oh, and my tester doesn't work since it didn't provide enough resistance to trigger the car into knowing something is plugged in. So you either need a tester that provides resistance or an actual trailer to test."
Hope that helps. It may also help if you buy a plug because then you can see how the wires would lock to the plug. They lock to the plate in a similar fashion I believe.
When you say that you removed the red plastic tab, did you truly remove it completely?
I did remove that red tab completely. Like you said I'll wait till the one comes in and I'm sure I can figure it out from there.
I remember being asked if I wanted it and I said no. I just got the hitch for a bike rack I've still yet to buy, and maybe tow something if the need arose.
