trailer mode camera
trailer mode camera
so we had the first trip with our trailer and our Q7 (2018 progressive with trailer hitch). I thought (based on manual) that there is a trailer view option when backing up once trailer is hooked up but couldnt find anything like that. It still beeps once trailer is hooked up saying audi pre-sense is not active anymore because of trailer hook up or something like that.
Is there a trailer mode in backup camera?
Went back to try it again. When hitting Parking assist the views that shows at the top are the standard ones. Then I select + to give options and I see "Trailer view" with the box unchecked. I check the box but nothing happens. I exit the Park assist and when I come back the "Trailer view" option isn't there anymore. Either I don't know the procedure to activate it or there is some bug with the system?
Also, you mention "trailer view option when backing up once trailer is hooked up". If I recall, the only thing that the trailer view option gives you is it changes the rear parking guide lines to a guide line that is supposed to help you align your hitch ball with the trailer tongue. So it is useful BEFORE you hook up, not so much after. Once you hook up and plug your trailer in the car's socket, the car should automatically sense that you are towing and deactivate the rear beeping noise. It also shows an additional signal in your dash when you turn on your turn signal, demonstrating that the turn signal on the trailer is working. All of that should happen automatically, but is dependent on plugging the trailer into your 7-pin socket. If those functions are not working, perhaps you have a defective socket?
I see. My expectations were different. If thats only the guide lines that changes well ghats not much then.
Yes, when hooked up there is extra signal sign in dash and it does recognize when hooked up.
Thanks for the help.
Or perhaps you are talking about Audi Trailer Assistant feature? I don't think this feature is available in the US or Canada...
https://www.audi-mediacenter.com/en/...assistant-2595
Just picked up a 2019 with factory tow package. I put it in reverse as mentioned, but cannot figure out how to click the '+' sign? If I select the ] on the input, it takes me to a menu for camera options, but nothing about the trailer view appears. Does the 7-pin plug need to be installed to make this active? I have a 7-pin plug on order (Pollak, not Audi as I hear they're the same and Pollak is 1/10 the cost), so currently the cover is over the factory wiring, as it left the factory.
The vehicle has the factory tow package (wiring included), not just the iron parts As described in this thread, in the US they don't ship with the 7-pin plug at the terminus, but do have all the wiring up to that point (https://www.audiworld.com/forums/q7-...ssing-2954605/). In this pic: you can see the wiring going back to the blank plate that comes from the factory. My wonder is, whether without the Audi (or Pollack, or other) plug yet installed, does the prevent it from thinking it has the tow package? Here is a link to the part I'm talking about (the less expensive Pollack version, which is supposedly who makes Audi's for them)
If I instead need to have it coded by Audi, I guess I can do that, but it seems pretty weird that from the factory it has everything but the final 7-pin plug, and I need to go in to have the 'authorize' me to tow.
