Transmission Swap ID
I need to swap out my Q7 2017 transmission. I found a used 2017 but it has a different Tran ID. My ID is SHS the donor ID is SUP. Are they compatible? Thanks!
Transmission should be OK. You only have to check the software version by PR number of your car.
https://cimg9.ibsrv.net/gimg/www.aud...7b84aa708.jpeg |
Originally Posted by joetimm1
(Post 25724439)
Originally Posted by retom
(Post 25724457)
Originally Posted by denvas
(Post 25895367)
Are the software versions able to be updated if swapping SHS to SUP though? looking to do the swap since a new one is 14k and not readily available and all used ones are 100k + miles. No informations anywhere about any of these transmissions.
Gentlemen, you'll need to get the component protection programmed to your vehicle ( tcu) is in the transmission. A competent programmer should be able to perform the task fairly easy, or you can put the vehicle on a tow truck and bring to the nearest audi dealer ( the car will start with the donor transmission but will not drive) . Just make sure they can do it before you go.
Originally Posted by Islandboycrec
(Post 25898041)
Originally Posted by n00bkiller944
(Post 25896539)
Loads of info on these transmissions - they are super common ZF unit. However, I am not sure on the details for how you code properly after. Hopefully someone chimes in
Yes you can swap over the tcu and it should work just fine make sure that the battery is disconnected when swapping.
Let us know how this goes. Will be a good resource for us all going forward!
