Vehicle Jack
Vehicle Jack
I picked up my new Q7 Premium Plus with 20 inch runs flats today. When I got home I noticed that the vehicle jack (which is pretty large and heavy) was secured in a small bag attached to one of then metal clasps in the rear. It was just sitting out in the back. Texted the dealer and he said that that's the way it comes from the factory. He said there is no spare (which I knew) but he thinks it fits in the compartment underneith the floor of the rear.
I lifted the floor and while there is a small space, the open area really isn't shaped properly to secure the jack. There seems to be some other equipment there (repair kit) and something which is under a large plastic shell (not sure what that is).
So is this where the jack is really supposed to be stored? It's very heavy and seems like it may shift around when driving. I don't want to damage anything inside the compartment.
Any help is appreciated.
I believe where it is 'supposed' to be stored is where you found it, on that tie down on the left. Mine was there too, probably the port installs them and that is the spot. I just tossed it in the area under the cargo floor to get it out of the way, though yeah, it doesn't have a spot there where it fits perfectly. With run flats and no spare I guess it isn't needed as much but since it fit I'll just leave it for now in mine.
Here's another thread from a new Q7 owner asking about the same thing, i.e. the mystery of the jack and its placement.
The quick and short answer is it is not needed. The Q7 has run-flat tires and it has an air compressor with a can of fix-a-flat. The idea is to use the fix-a-flat on the punctured run-flats to allow the owner to get to a tire shop. So, it is best just to leave the jack at home. Unless, you want it flopping around under your Q7's trunk.
It's the perfect paper weight!
Hmmm. We ordered the Q7 Prestige with the 21" tires and wheels to avoid the run flats. I wonder if we get a sparre tire? Guess we will find out in a couple of weeks when it arrives, but if any forum members know, would appreciate your thoughts.
BTW - only the 20" tires are run flat. The optional 21" "summer performance" tires are not.
Thanks for that. And yes, we ordered the 21's to avoid the run flats.
I drove 200k miles in Corvettes with Michelin non-run flats and no spare. No flats!
Snopyro
Q7 MK 1 Discussion
11
03-05-2018 05:14 PM
kday
Audi Original "S" Cars
09-15-2006 05:07 AM
Car Crazy
14
08-08-2005 08:53 PM
