Video: How the Power Trunk Lid Operates and Hands Free
I was at work today and decided to show the proper motion necessary for the feature to work as well as all of the other ways to operate the trunk lid. The car must have advanced key and the ignition must be off. Your key fob is not active when the ignition is on.
Nice video, thanks. One note about the kick feature... if you have the trailer hitch installed, you probably don't want to kick right in the center as you will bang your angle on the hitch. Fortunately, it works fine if you kick on either side of the trailer hitch. I find that if I gently tap my toe up under the bumper, it works every time. If my foot is lower (closer to the ground) it is not as reliable.
Thanks SYMAWD - is there a way to change the behavior of the FOB or the switch in the door so that you don't have to hold down the button or pull on the switch the entire time to close the trunk? I suppose this is Audi being 'safe' with the feature so as to not have someone get hit by the trunk presumably if you're holding the switch. I've never had a car that made you do that - usually just a double tap of the fob and it would close regardless.
What happens if you let go of the fob or switch mid-close? Does it just stop or revert back to open?
I still haven't found a good video of the traffic assist function. Would love to see it in action. Also I have the Prestige coming and would love to see the different lighting options you can do in the cabin - I know it has the color wheel but can you do different colors for different sections?
