AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   Q7 MKII Discussion (https://www.audiworld.com/forums/q7-mkii-discussion-211/)
-   -   View cameras while in drive? (https://www.audiworld.com/forums/q7-mkii-discussion-211/view-cameras-while-drive-2966947/)
peterish111 02-08-2019 07:54 PM
Is there a way to manually switch on the external cameras while the car is in drive, such as while pulling into a parking spot or garage? So far it seems the camera system only switches on while in reverse.
Paul Collurafici 02-08-2019 09:00 PM
Push the P button. It will only work when almost stopped and go off as soon as you drive. The P button in under the screen to the right of the other hard buttons.
hayde_bre 02-08-2019 09:00 PM
Hit the P^ button on dash for on-demand camera action.
Otherwise, your parking sensors and cameras should come on in tight parking spot, if you are hearing beeps but no camera (aside from top view graphic bug), get it checked.
BarryT 02-09-2019 04:53 AM
They’re set to shut off at a certain speed. I increased the speed to 20 mph on mine and that is the max.
BigKutta 02-09-2019 05:11 AM
Interesting...I didnt know we could do that. Mine must be set to 5mph
Verybumpy 02-09-2019 06:20 AM
How is this adjusted?
SCarGuy 02-09-2019 06:33 AM
Vagcom should allow you to alter the max mph. That's the only way I know of
alex123 02-09-2019 09:33 AM
obdeleven
lapi 02-09-2019 11:58 AM
Use OBDEleven
Increase the speed at which parking assist turns off
  1. 09/Central Electric
  2. Adaptation
  3. Switch off spd for park assist
  4. 20 (old value 10)
RickObe 02-10-2019 10:09 AM
Originally Posted by lapi (Post 25273977)
  1. 20 (old value 10)
BTW, that's in k/hr, so the top limit is about 12mph.
