Wheel Spacers on Factory 21's
2017 Q7, Artic White, Black Optic
Lowered 1.25" all around.
Looking to even out the wheel to fender look. Have OEM 21 wheels. Thinking 12.5mm front, 20mm rear, ECS brand.
Comments...?
Issues...?
Comments...?
Issues...?
Hello, I run OEM 20" so not quite the same, but I have 15mm front 20mm back and I think there is still room for another 3-4mm on both front and rear.
In your Case and comparing OEM specs, you'll be just about perfect with 12,5-20mm.
Hope this helps somehow
And 0 issues so far, 10K miles or so
stock 19's
guys I'm doing the same so any direction on best spacers?
i have stock 19's and want to get the wheels flush also.
so what size? and where to get? any help is much appreciated
thnx
j
thnx
j
would need to know the 19" specs. Whats the width and offset would help with recommending spacer size. You could also just measure yourself and go from there. Youtube a few videos i think ecs has one that shows how to correctly measure for spacers.
Can anyone confirm these ECS spacers are the correct part numbers to use on a 2017 Q7;
12.5 mm thk
#2748284
20 mm thk
#2748291
Want to make sure they are the right bore and bolt pattern.
12.5 mm thk
#2748284
20 mm thk
#2748291
