Why does my map revert back to standard from satellite?
Just picked up a 2019 Q7 as a kid hauler for my wife. Have noticed some quirks lately, namely that the map will randomly revert back to standard from satellite. I have to go into the menu and re-select satellite and then it flips over fine. Sometimes it stays...other times I start the car and it has gone back to standard. Anyone know if I am missing something??
Thanks, Kent |
Happens on both my 2018s as well, along with the overhead camera shift to graphic. I've just chalked it up to Audi and moved on. Maybe a software update needed, but I assume your 2019 already has the latest. Reliable high tech programming does not seem to be a core strength of Audi.
Originally Posted by Doc H
(Post 25304083)
Originally Posted by Brimstone
(Post 25304107)
To be completely fair its not really a core strength of a lot of so-called tech companies either! (but I totally agree about Audi)
Originally Posted by Karrera4
(Post 25304061)
Thanks, Kent I know when I had Audi connect there were times when it would not connect right away. I dropped the service since it will not pay $499 for 18 months for real time traffic info which is basically the only Audi connect service I used. |
Originally Posted by dbull
(Post 25304544)
Just a thought. Google Earth map requires an internet connect through your Audi Connect subscription. If the car does not make a timely connection the map function may think the service is not available and default to the standard map. Another option is that the Audi Connect server (in the cloud) may have an issue with the google earth function so you car will not have the ability to show google maps.
(Post 25304061)
Thanks, Kent Bob |
Originally Posted by bobby111333
(Post 25304815)
I've had the same problem since I got my SQ5 in February. I've asked both my stores in Tampa and Miami and they have different answers. One technologist said Audi servers goes down often and when that happens it kicks you out, but you can switch it back. A different technologist told me that should not be happening and verified my Audi account subscription to make sure it was active. It was and he said if it did it again bring it to service to see if there was an update. I brought the issue to my advisor and she also said it shouldn't be doing it and she'd get back with me to see if there was an update or if she could get any more info. Didn't hear back from her. So, I've been just leaving it on standard maps. It's annoying to keep switching it over. Next time I'm there I'll bring it up again and see if there's an update on the issue. If it doesn't stay on satellite maps, there's barely a reason for me to keep my subscription when the time comes to buy... Love the rest of the car, though
Bob |
Happens to me all the time in my 19
in my S5 sportback and prior 2018 Q7 prestige this happened as well. the recent mmi software update seems to have fixed it. version 1316. sometimes it helps to search the forums to find fixes rather than accept substandard electronics in vehicles this expensive.
