Will these wheels fit the 2017 q7 ?
3 Attachment(s)
Hi I ordered a prestige and now regretting not getting the upgraded 21"wheels. Standard prestige wheels are rather boring and don't do much for the q7 in my opinion.
Was looking online to see what I can get that fits but don't know the specs of the oem 21" wheels. Anyone know? Was interested in these... Will they fit? Thanks |
That's a lot to spend considering it's only a $1,000 option. I can tell you that in dealing with the issues involving just being different tires for the 21" rim you would be best served if you called an Audi service department and have them look it up.
Pretty sure they will not I believe the bolt pattern changed from 5-130 to 5-112
That's correct. The bolt patter did move to 5-112. TireRack just updated their system and now lists several wheel options for the 2017. Now, to decide on which wheel. I really like the BBS CX-R!
Originally Posted by imcav8r
(Post 24773925)
If anyone has the stock offset that would be great as well! |
Perhaps have gotten carried away with my wheel and tire research but here are some specs.
Stock 20" tires on '17 Q7 = 44 lbs (each) Stock 20" wheels on Q7 = 35 lbs (estimate of each) TOTAL = 79 lbs (each) 275/40/20 Continental DWS Tires = 35 lbs (each) 20" TSW Interlagos wheels = 25 lbs (each) TOTAL = 60 lbs (each) So that's a 19 lb per corner savings for 76 lbs overall of unsprung weight!! |
Sasmf did you find out which TSW wheels will fit the 2017? I have a call into a local dealer but have not heard back. I am looking at 20" for winter and Hakka R2 Suv for tires. I am just wondering which tires I can pick from? Did you find out correct offset?
Well, I'm about 99% sure at this point that the bore size is 66.56 like almost all other Audis. Tire rack recommends an offset of between 32 and 39 mm. I like the TSW wheels but all of them will require hub centering rings and because of the Q7's weight I want to run a hub specific wheel so that has led me to the following:
VMR V810 VMR Audi VW Mercedes V810 19 inch Wheels - Flow Forming Avant Garde M510 Avant Garde Audi Type M510 19 inch Wheel Set Hartmann wheels (almost any of these) Hartmann Wheels - Audi Wheels, stock replicas - hartmannwheels.com I'll update this post as my research continues. |
If you are that unhappy, it may be cheaper to just go to your dealer cut a deal with him re: cancelling the order and ordering a vehicle with the 21 inch wheels.
Originally Posted by Amit128
(Post 24769648)
