Winter tires for new Q7?
#21
Cadx6, If you don't mind sharing, how much is your tire guy charging you for storage? The local Audi dealer here charges $125 per season (so $250/yr), and I'm wondering if that's the norm.
LarryV and others, are you choosing to have the spare set stored at the dealer/tire place or just at home?
Has anyone tried transporting 4 tires (mounted on 21" wheels) in the back of their Q7? I wonder if they would fit with the 3rd row down, in case I decide to store them myself and have to lug them home.
Thank you!
Thank you!
I would love to store them at home but with a three car garage currently housing three cars, two rolling trash bins, my work bench & a snow blower - it just ain't going to happen
I got the Audi "Tire Totes" and felt pads which we installed before they went into storage. Good investment, they really protect the wheels.
#22
The wheels didn't come with any lug bolts but I contacted the seller & he verified that they use the stock (ball) bolts. We also physically verified this at the tire shop.
#23
My shop (Suburban Tire) charges $100/yr.
Did you get the totes and felt pads online?
#24
I kind of wanted to store the winter set at the dealer but despite being newly constructed, they don't even offer that service.
#25
AudiWorld Expert
I have used Pirelli Scorpion Winter XL... I wanted Dunlop WinterSport however not available in 21" fitment. I was told by a few MB owners that these work great, apparently the popular choice among Canadian MB Drivers. I did not have any issues or complaints.
#26
Audi A3, A4, A5, A6, A7, A8, TT, and S/RS derivatives use R13 (13mm radius) ball seat lugs.
Many aftermarket replicas wheels use conical seat lugs... so you must use caution in determining if this is the case so that you don't mistakenly use the oem R14 or R13 ball seat lugs that came with your car on the conical seat replicas.
There are exceptions: Hartmann wheel replicas and possibly a few others also use R13 ball seat lugs, which means you can reuse the lug bolts that came with your new Audi sedan or coupe. However, if you have a Q5, SQ5, or Q7, then you'll need to acquire a set of R13 lug bolts because the R14 would not properly seat on the Hartmann wheels without possibly causing damage or inaccurate torquing of the bolts.
Since I'm using original Q5 S-line 20" peelers as winter wheels on my Q7, the R14 bolts that came with the Q7 will properly seat on these wheels.
Basically, unless you're mounting a set of original Audi Q5 or Q7 wheels on your Q7, you should not be re-using the R14 lug bolts that came with your Q7 and will need to acquire a different set of lug bolts (conical, R13, or whatever) that will properly seat on your aftermarket wheels.
#27
Thank you!
Thank you!
#28
Did a lot of research on the winter wheel setup. Ended up going with 19" replicas same design as the 20" models shown earlier in the thread. They match the 21" nicely. Bought 255/55 r19 Michelin x ice i2 for $229/ea mounted and balanced. All 4 fit easily in the back even with one if the second row seats occupied.
Purchased r13 lug bolts on eBay for less then half ecs tuning is charging. Center caps purchased off amazon.
All in all everything worked out great. Glad to have the winter set vs the all seasons here in the northeast. Curious to see how he car rides as the with the summer rubber, the ride is as smooth as glass.
#29
Thank you, Jalf, Cadx6, Larry and everyone else. The information you've all shared is incredibly helpful.
Although, the more you share, the more questions I have. I hope you'll bear with me.
These are the wheels I'm considering,
http://www.ebay.com/itm/20-Wheels-Audi-A8-A6-A5-B8-A4-A7-Q5-VW-CC-Tiguan-20x9-0-Inch-Rims-Set-/391605553860?vxp=mtr&hash=item5b2d828ac4
If the link doesn't work, here are the specs,
Rims Size: 20x9.0" fronts and rears
Hub: 66.45 ( free hub rings included 57.1 as needed )
Offset: 35 mm fronts & rears
Bolt Pattern: 5 X 112
Will these fit the 2017 Q7?
If I do end up needing the R13 ball lugs, what do I search for on Ebay/Amazon, etc? Ebay returns several listings for R13 ball lugs with different shank sizes (32mm, 40mm, etc.), so I'm confused.
Lastly, I see that some of you are not going down too much in wheel size. For those getting 275/45/20 for your winter setup, are you not giving up some winter performance compared to a higher profile tire on say a 19" wheel?
I'm worried the 19s might look puny on the Q7 but also don't want to give up meaningful winter performance just for looks. Interested in your thoughts.
#30
20" Wheels For Audi A8 A6 A5 B8 A4 A7 Q5 VW CC Tiguan 20x9.0 Inch Rims Set | eBay
I decided to just go down to 20s since I hate the look of small wheels on a vehicle as big as the Q7 and where I am, we don't regularly get 4 foot blizzards & the roads get plowed fairly quickly - plus, those Blizzaks are pretty aggressive, much more so than your average "all season".
