Winter tires for new Q7?
#41
No, you can't use any 20" tire. You have to ensure that the overall diameter of the new tires is within a couple of percent of the original size. This tire size calculator recommends within 3%, but the closer to OEM diameter the better.
Tire Size Calculator - Tire & Wheel Plus Sizing
1) 275/45/20 (sidewall height: 123.75 mm, diameter variance: -1.18%)
2) 265/50/20 (sidewall height: 132.50 mm, diameter variance: 1.11%)
Leaning towards option 2 as that gives me more sidewall and a slightly narrower tire. Tire Rack does list 265/50/20 as a winter tire option implying it will fit?
Anyone have any thoughts one way or another, between these two options? As always, your inputs are greatly appreciated.
Thanks!
#42
NABS4, Thank you that tip, that calculator is great. I want to go down in width compared to the OEM 20" (285/40/20), and I've narrowed my choices down to these two,
Thanks!
Thanks!
#43
I would go with 255/50/20 as it is within 0.3% of the stock 285/45 R20. So your actual speed at 60 MPH would be 59.8.
With the 265/50/20 it's a 1% difference so at 60 MPH you will actually be doing 60.6.
#44
You, Sir, are correct. Thanks for pointing that out. I'll see if 255/50/20 is available in the Nokian Hakka R2s. Placing order in the next couple of days.
#45
Turns out the 255/50/20 Nokians are out of stock nation-wide. Demand was higher than expected and Nokian sold out, new stock is expected to arrive around the first of the new year (according to tiresbyweb).
265/50/20 is available, and I know it will fit but just not as close to stock as the 255.
What would you do in my place, wait for the 255 or get the 265? I live in MA, there's probably a 50/50 chance of meaningful snow by early Jan.
#47
Thanks for sharing your thoughts, Lookout.
#49
Yes, I want to stay with Nokian. With the 265/50/20, I get a little more sidewall (+ve?), but a little more width (-ve?) as well. And the greater speed variance, does that hurt the car in any way/cause more wear, or is it just an annoying measurement error?
#50
I just bought Continental DWS06 275/45 20 $225 each
20X9.5 AVARUS AV15 TITANIUM 32 offset. $99 each
From Tirerack. $1580 total Just to use in winter months. Summer 21" came on the Q7. Not real blown away buy the look but will get the job done and great price
