Would coding the car void the warranty?
So I've been messing with coding in the Q7 for a while. Wondering if coding the car would void the warranty? Especially if something go wrong in the electric system, folding mirror, sunroof, windows, for example, would the dealership blame it to the coding that I did? They could tell if I made the coding, because I retrofitted the auto hold button and dynamic tail lights, so it's easy to tell. Any first hand experience?
on the simple coding probably not. if they were ever to even try it would have to be a perfect storm
retrofitting stuff may void something only case specific to the issue that would happen
No. Because when your’re coding (I assume you mean with VCDS/OBD11) you can reverse your changes. With VCDS i make sure to log my changes. If there’s an issue whereby a MIL is thrown you can always correct the error and clear it. I’ve been around here for a few years and have never heard of anyone having issues with dealers because of coding. CC’s SA was providing a CYA corporate response.
Thanks for the info. Yes I guess if anything wrong with the parts that related to the coded module, Audi might blame the coding and void the warranty. It's a pain in the a$$. So is coding still worth risk?
15 years of coding my audis and never, ever been told it was a problem and never discovered that I had changed anything. I think that tech was either confused (chipping your car - a physical change in the ecu - does flag the car)... OR... he was BS'ing you.
Void the entire warranty...NO. Refuse a warranty claim related to a specific module/system that you coded... YES, possible. See this:
I don't think any of the VCDS coders will tell you not to do it - the chip moders might say something different however - the TD1 is scary indeed, but not sure who on this forum was denied a claim due to a TD1.
