XPEL for the New Q7
#11
While some have done it, doing the sides of the car isn't very cost efficient. There is very little chance of a rock damaging the sides - almost all the risk is the front surfaces. It's a risk vs. cost decision.
BTW, one reason for the expense of a full front is a piece to cover the entire hood must come from a 60" roll which is costly (about $600 by itself to install). A partial hood bra is a fraction of the cost but will not be as protective and the seam will be visible.
I would also note that not all films are the same. Xpel Ultimate is the only film on the market that has self healing properties, a clear coat layer like your paint and a 10 year warranty including film and labor. It's not the lowest priced film on the market but probably the best. Doing a bra with a less expensive film could easily be under $1000 but a full front with Xpel Ultimate including a full hood with wrapped edges and paint prep will not be possible. Just like an Audi compared to a VW, there are valid reasons why one costs more than the other. That said, one should still shop around.
#13
No. Xpel and other similar films prevent paint damage from lightweight debris like small rocks as they hit the surface at speed. They will not prevent the bending or denting of metal as it gets hits by larger heavier things with greater force like the edge of someone else's door slamming open into yours. They will do a good job of preventing sharp edges from penetrating the paint but if the force is heavy enough, the underlying sheet metal will still deform. This is especially true of aluminum outer body panels as they are inherently softer and more prone to being dent. While the Q7 benefits in many ways from the use of aluminum in terms of weight savings, it is very likely that it will be at the expense of being more likely to get door dings from even lighter hits. At least this was my experience with various cars I've owned with aluminum body panels. Sheet aluminum just dents and bends easier. Luckily, paintless dent-repair is almost always successful though slightly more difficult to do with aluminum according to the PDR guys I use.
#14
I am in NY and just got a quote of $1235 for Xpel Ultimate on the front bumper cover, mirrors and full hood. I will probably have it done. Had it on a Cayenne GTS and it worked well.
#15
Consider adding the front fenders. They are at as much risk as the hood from stones, gravel and such.
#16
As to aluminum, the alloys being used today are stronger than in previous years. After I was forced into sideswiping a guard rail last summer, I got to know my Audi Certified Collision Repair Center guys pretty well. They are certified to repair aluminum and have the special training, tools and clean room necessary to do the body work. They told me while aluminum body repair still requires more time and skill (as evidenced by the insurance estimate costs), the strength of the material has improved considerably over the last two or three years.
#17
I think the experience of the installer is key. We picked up the Q7 today. I cannot find a flaw from the bumper to the front of the front doors. Attention to detail is perfect down to the underside of the splitter. Full hood, full fenders, bumper, splitter, headlights, headlight washers, mirrors and no defects: + 30 % Wincos IR film on the two front windows. $2100 all in. Love it! He does my '13 S8 in two weeks.
#18
Sounds like it was installed as it should be done. I agree, the installer makes the difference. I do have a question..it took them two weeks? My installer is rated as one of the top ten custom detailers in the U.S. and it took them two and a half days. That's with a complete full front, rocker panels using custom cuts (no kit) and Opti-Coat Pro and Plus applied after the film. Also a flawless job.
#19
Xpel
#20
