Aslo... starting/car dying
Old 11-04-2003, 02:15 PM
New Member
JasonEisen's Avatar
Default Aslo... starting/car dying
WHen i first start the car.. after it catches on and starts running... i have to give it gas for 30 seconds or so to keep it running, or it just puts and dies on me.
Also.. even after driving for 30 mins (so the engine is definately warm) going from higher (3k) rpm to idle, it just dies sometimes.
This an idle control valve? I had an old 4k that did the same thing sometimes.
What about starting.. cold start valve?
Old 11-04-2003, 03:17 PM
Kidquattro's Avatar
Default Re: Aslo... starting/car dying ...could be both...
...but I'm guessing seeing that mine sometimes takes a pump of the gas to get running.
Old 11-04-2003, 04:09 PM
New Member
JasonEisen's Avatar
I just went and started it... it doesnt even idle now. How do i raise the idle?
Old 11-04-2003, 06:31 PM
New Member
JasonEisen's Avatar
Default Ok, i checked some wires...
One was completely broken loose on the switch that is pressed when the gas is pressed to the floor... sorry i don't know the name. Boost throttle? So thats why that wasn't working. Reattached.
But the one that is released when you actually press the gas is connected fine. I don't have a voltemeter or whatever to check it... but i assume its working because the car is at least attempting to idle.
I don't know what to do
Old 11-05-2003, 08:26 AM
fusilier's Avatar
Whats the cranking duty cycle?
Old 11-05-2003, 08:43 AM
New Member
JasonEisen's Avatar
the whata whata?
Old 11-05-2003, 11:56 AM
AudiSport4000's Avatar
My 4kq did something similar. When moving in gear, when I would go to toss it in neutral, the revs would drop, car would stumble, but catch itself. Coolant temp sensor was the culprit, it fixed my very hard starting problems too.
HTH
Mike
Old 11-05-2003, 12:02 PM
New Member
JasonEisen's Avatar
Default PROBLEM SOLVED
I raised the idle a little bit... 1100 RPM (hee hee)
Adjusted the fuel mixture.
Sitting at stop lights is almost as joyful as driving now....
well not really
OMP
11
04-28-2019 08:13 AM
bartzgs
10-21-2008 07:13 AM
nfs1000f
11-13-2006 06:57 PM
ikencya
04-12-2001 07:25 PM
SteveAngry
Misc. Models Discussion
02-11-2001 07:01 PM
Quick Reply: Aslo... starting/car dying
