guys need a little help ! BBS RS 008 and 009 wheels....
would fit the Ur with no rubbing issues?!or I would need 008 all around?!
I did some test fitting, and it didn't look like the 009's would fit without rubbing
and that's on an 85 with the factory rolled fenders. See my post below with pics and details.
I didn't try it with tires installed as you can see from the post, I just mocked it up, but the extra inch of width on the 009's is all to the outside compared to the stock R8's, so it's pretty unlikely that you'd be able to fit them without modding the suspension pulling the fenders, or something else pretty extreme. The RS008's are the same offset as the R8's and narrower, so they fit no problem.<ul><li><a href="https://forums.audiworld.com/quattro/msgs/22167.phtml">RS008 and 009 test fit post</a></li></ul> |
Thanks! did you install them?! or you are selling the 008 set :o)
I actually ended up with both a complete set of 008's and a staggered set...
LMK if you're interested in the 008's.
Re: I actually ended up with both a complete set of 008's and a staggered set...
how much ?
I've got a few people asking, so I'll probably post them on Audifans
It'll probably be Monday before I can get pics and get them posted though.
