quick tranny question
i think my 84 4kq has an 016 trans? its the close ratio one. is that the same in the 83 and 84 urq? or if i had an urquattro and wanted my mack truck gearing would i have to stuff the 4kq tranny in there? thanks urqers
Re: quick tranny question
I'm pretty sure the transmissions are the same. The final drive in the urq is 3.89:1. I think it's the same in the 84 4kq. In 85-87, the final drive is 4.11:1.
HTH
HTH
Yes, it is an 016. ALL ur qs have 3:89 FD, ALL 4kqs have 4:11 FD.
If you want 4:11 FD in an ur q, you will need the rear diff from an '84/early '85 4kq with the one piece housing.
axles are the only thing different...
F&R subframe, mounts, etc. same PN#'s
prop shaft SAME PN#'s
shift linkage SAME PN#'s
the quattro uses 2 of the 857 407 271 A and 2 of the 857 407 272 A complete drive shafts and that is the only difference
Same part numbers as what, an S2 or a Euro S4?
Are you saying an S2 6sp tranny(CRB), will fit into an UrQ without any modification to the subframe? That would be nice...
And will the retaining clip for the shift linkage ball(at the tranny), from a US 90-93 Quattro Coupe fit the S2 6sp tranny? I need a replacement part and I would love to hear it's the same part no. as the European counterpart.
Thanks,
Fruitman
Thanks,
Fruitman
coupe d'mike
11
07-08-2005 11:09 AM
Merkin
06-05-2004 09:40 AM
- GT Style -
12-30-2003 10:48 AM
BigMouse
02-28-2003 10:04 PM
