Removing rear seat
Hi,
I feel like an idiot.... I cannot figure out how to remove the upright part of the rear seat from my 83 URQ. Any instructions or guidelines out there - I dont want to damage it by forcing it out... Thanks |
Hello casso,
there are two hooks in the cushion that click into the upper part of the rear separation to the trunk. When you look from the back (trunk you can see them close to the mounting of the seat belt. You have two options: 1. Get a long metal hook to pull the hook away from the separation wall and have somebody else inside lift the seat cushion up. 2. If you are strong enough in you hands you can manipulate (bend towards you) the hook from the inside and lift the cushion. Ciao Werner |
Originally Posted by wego0002
(Post 25080538)
Hello casso,
there are two hooks in the cushion that click into the upper part of the rear separation to the trunk. When you look from the back (trunk you can see them close to the mounting of the seat belt. You have two options: 1. Get a long metal hook to pull the hook away from the separation wall and have somebody else inside lift the seat cushion up. 2. If you are strong enough in you hands you can manipulate (bend towards you) the hook from the inside and lift the cushion. Ciao Werner Frank |
:D:-))))))))))))))
It worked! I had to really wrestle with it, but after about 30 minutes of sweating, cursing and brute force .... I got it out.
Thanks! |
