spark plug and ignition wire set
I have installed a new set of plug wires (Bosch 09008) and the wire that goes from the coil to the distributor is about 3&1/2" too short. I talked to Bosch and they said a 09514? set may work. However that set was too short as well. Both were supposed to be oem replacement but I have not found that to be true. Is there another alternative to Bosch or a different part number I could try out?
I think bosch may be shorteneing all of their products because that is also the case on my Starion. I took a look at a set yesterday which is identical in part number to one I bought last year. Coil wire is too short by about 3 inches. Strange.
Found out autozone had a length that was exactly what I needed. 7mm grey silicone ignition wire for only 4 bucks. In the end, I had to use the spark plug set 09008 bosch supplies plus the autozone part. I also got a new old stock radio put in along with the diff panel and a new washer fluid reservoir pump. Whoo hoo.
Found out autozone had a length that was exactly what I needed. 7mm grey silicone ignition wire set for only 4 bucks. In the end, I had to use the spark plug set 09008 bosch supplies plus the autozone part. I also got a new old stock radio put in along with the diff panel and a new washer fluid reservoir pump. Whoo hoo.
EctoA3
03-10-2018 01:59 PM
sidespar
11-22-2004 02:28 PM
TurboEnvy52
08-16-2004 09:56 PM
Audi100s1993
Audi 100 / A6 (C4 Platform)
06-14-2003 06:04 PM
nanotech
08-15-2002 03:39 PM
