White Smoke, Low Power, Hesitation at Low RPM.
The white smoke goes away after the car has been run for about 15 minutes. The hesitation occurs consistently when I press the accelerator at low rpms only (1000 - 1700rpm). I also saw white smoke coming from the large rubber hose that goes into the top of the intake manifold toward the front of the car and I know I have at least one vacuum leak I can hear in the cabin of the car. I also have been told the the tailpipe/muffler is too small and restrictive for the car.
Anything else I should fix or consider? It appears that I am not losing coolant into the head. Could the white smoke/low power be from the vacuum problems? Anyone have a part number for the large hose that goes into the intake manifold?
TIA
TIA
Well, My Guess
Is that the turbo is leaking water into the turbo's oil bearing and its boiling off into the intake tract/and or the exhaust. Is there any water in your oil?
Thats pretty much the only consistent source for white smoke coming into the intake. Might make some interesting water injection technique :-)
Aside from that, the turbo bearings of the center section seem suspect as well. Interesting thing is obviously, someone did a water cooled turbo conversion to your car. Who installed it and how old is it?
Re: Yes could be,
Thanks for the input. Looks like I am
going to have some hands-on professional diagnosis done before decide what to do next. Maybe the engine swap should be done sooner
than later. Hopefully it is just a head
gasket, vacuum leaks, and the turbo.
