Cylinder 2 misfire problems
So my 1.8t started to idle really hard today and was throwing a blinking CEL. I tossed on the VAG and it was saying I had a cylinder 2 misfire. I instantly pulled the plugs to check them, swapped plugs, swapped coil packs to try to narrow them down. This didn' change anything. It is always throwing a cylinder 2 misfire. I then though it could be the fuel injectors (which it very well still could be). I pulled the fuel rail and the injectors and #2 definitely had some gunk on the end of it. I cleaned it up but put it back into the same spot because I jacked my shoulder and just wanted it to be back together at that point. Anyway, long story short it still is throwing a cylinder 2 misfire every time. Since this injector was gummed up is it probable that it is the injector that is causing the issues, or what else can I look for?
Thanks much in advanced
Might very well be your power output stage. If you have a multimeter you can unplug the...
cyl 2 coil pack and check for signal. Most of the time when the POS fails it results in cyl 2 misfire.
Photoputz83
1.8T Discussion
09-25-2019 04:07 PM
Alexandroff
11-21-2017 01:45 PM
S4intheOC
09-08-2015 12:12 AM
anticsAK
09-06-2015 05:34 AM
anticsAK
09-04-2015 09:59 PM
