RS 7 Discussion forum for the Audi RS 7
Presenting the new AWE Audi C7 4.0T S-FLO Carbon Intake!
Old 11-30-2017, 12:33 PM
Audiworld Basic Sponsor
Josh/AWE's Avatar
Arrow Presenting the new AWE Audi C7 4.0T S-FLO Carbon Intake!
Presenting the next generation of the AWE S-FLO Carbon Intake for Audi C7 S6/S7 and RS6/RS7:
  • Proven power on Stage 1 and Stage 2 cars, with and without downpipes
  • Max gains of 32 hp and 50 ft-lbs of torque @ 3150 rpm, crank (RS7, Stage 2 software + downpipes)
  • Max gains of 15 hp and 27 ft-lbs of torque @ 2670 rpm, crank (RS7, stock software)
  • Max gains of 24 hp @ 3250 rpm and 36 ft-lbs of torque @ 3150 rpm, crank (S6, Stage 2 software + downpipes)
  • Max gains of 15 hp and 19 ft-lbs of torque @ 4020 rpm, crank (S7, Stage 1 software)
  • Completely redesigned to support higher power applications
  • Durable and washable high-flow AWE S-FLO Filter included
  • Perfect integration with OEM inlet ducting
  • Smooth transitions from full carbon fiber airbox inlet and turbo inlets
  • Retains stock mounting locations
  • UV-stabilized resin and clear coat
  • Perfect fitment - guaranteed
  • No Check Engine Light Guarantee
The C7 4.0T S-FLO Carbon Intake:
Full floating carbon construction, no silicone. The AWE C7 4.0T S-FLO Carbon Intake features full carbon fiber construction allowing smooth transitions of airflow from the grille inlet to the turbo inlets. By deploying a new grille-mounted air box inlet, and utilizing the factory accordion turbo couplers, the S-FLO Carbon Intake floats in place under heavy torque situations, preventing strain on the carbon fiber.
In other words, this box has both the looks and performance to earn the AWE S-FLO badge.
The S-FLO Filter:
The included AWE S-FLO Filter is designed specifically for the AWE C7 4.0T S-FLO Carbon Intake to ensure easy service and to maximize airflow by sitting in the direct path of ram air from the grille. The combination of S-FLO carbon airbox and included S-FLO Filter makes for a more aggressive intake note, with a distinctive turbo spool sound when under boost and letting off of the throttle.
Power testing:
The AWE C7 4.0T S-FLO Carbon Intake has been power and quality tested on the stock setup as well as under aggressive stage two conditions which incorporated high-flow downpipes. The AWE C7 4.0T S-FLO Carbon Intake produced healthy gains in all scenarios, and has withstood long-term real-world testing for quality and performance.
Add in our new enlarged, integrated honeycomb-meshed port located on the top of the S-FLO’s air box, and you’ve got optimal airflow even when pushing higher-than-stock boost levels.
Data - RS6/RS7:
Data - S6/S7:
You’ve got questions? We’ve got answers. 1.888.565.2257, 215.658.1670 or performance@AWE-Tuning.com.
Josh Davis > Performance Specialist
AWE-Tuning.com > 1.888.565.2257
my email > facebook > twitter > instagram > youtube
Old 12-07-2017, 07:49 PM
Sierraflyfisher1's Avatar
Just had one installed today on my tuned 2017 RS7 Performance. Engine light is on.
Old 12-08-2017, 04:20 AM
Gsrjc's Avatar
That's not good. Let us know what you discover as I'm sure there are a few of us that are interested in getting one of these. Is it possible that since your RS7 is tuned, it doesn't like that?
Old 12-08-2017, 10:03 AM
Josh/AWE's Avatar
There's no MAF sensor on there to cause a CEL. Never has there once been a CEL during our intake testing on this platform, even dating back to the beginning in 2014/15.
I recommend you check your codes to see what else is going on.
Also, welcome to AudiWorld!
Old 12-09-2017, 03:52 PM
Gsrjc's Avatar
Could I get some more information on the intake system? I have a stock RS7 non performance.
Old 12-11-2017, 10:16 AM
Josh/AWE's Avatar
Of course. Feel free to email me or PM me.
Old 03-29-2019, 11:09 AM
Josh/AWE's Avatar
Get your AWE S-FLO Carbon Intake right this way.
Old 04-10-2019, 03:11 AM
rscultho's Avatar
Would you mind providing some detail between the first generation model intake and this upgraded version? After having read at least two accounts of RS7's with turbo impeller damage after having these intakes installed, I'm curious to see what improvements were made in this version of the intake.
Thanks
Old 04-12-2019, 12:10 PM
Josh/AWE's Avatar
Thanks
Sorry, turbo impeller damage? With the Gen 1 SFLO? Is that a blanket statement about all intakes on these cars? I have never once heard of that, let alone because of our intake.
The Gen 2 features a new floating inlet, grated opening at the top of the box, and full carbon outlets. Completely silicone-less.
Josh/AWE's Avatar
Thanks
Sorry for my ignorance, turbo impeller damage? With the Gen 1 S-FLO Carbon Intake? Is that a blanket statement about all intakes on these cars? I have never once heard of that, let alone because of our intake.
The Gen 2 S-FLO features a new floating inlet, grated opening at the top of the box, and full carbon outlets. Completely silicone-less.
Quick Reply: Presenting the new AWE Audi C7 4.0T S-FLO Carbon Intake!
