2008 RS4
Hello all,I need your knowledge. A local dealer has a 2008 RS4 with approximately 75k. My question is I currently own n E46 M3. I love the car but would line something I can drive year round (I live in mich) and would also like something that is a little less maintenance intensive. Assuming the PPI checks out are these birds of the same feather or is the Audi a little more user friendly? Thanks in advance, I do appreciate the help.
similar cars from a maintenance standpoint. Given your climate, RS4 can be far more usable. RS4 is also far rarer and will absolutely hold it's value better than the E46.
Thank you. Similar as in I should plan on dropping 5k in preventive maintenance? What are the common issues to look for on the RS?
Originally Posted by Cyruszx7
(Post 25149010)
The big ones - high pressure fuel pump/cam follower due to carbon build up, and timing chain tensioners. Low pressure pump goes at some point too, but that is a simple job. If the car has had at least the carbon treatment done (or at the very least, regular cam follower replacements), and especially the timing chain tensioners, etc. done, all other things being equal, it should be a very robust vehicle |
Don't know how or why but this car is at a Ford dealer. If they have no history on the vehicle is reason enough to stay away or let the PPI determine that.
Why does it matter what dealer has it?
Carfax will have history of maintenance on the car if it was done at a dealer (or even some indy's). Let a PPI determine the condition if you're serious about the car |
Originally Posted by SCarGuy
(Post 25149033)
(Post 25149010)
-Recent Carbon Clean -Brake Rotors/Pads -Sticky clutch -Oil cooler lines corroding at insertion point (causing leaks) -If it still has the original DRC Suspension, check for leaks -Injectors -Check the CV boots for leaks/tears For the most part though, these cars are very solid besides the need for an occasional carbon clean.
(Post 25149016)
I checked out the carfax and there were only 11 service records recorded ,most sounded like oil changes. There were a couple fuel system cleanings,not sure if that is the carbon clean. Something else struck me as odd,there were 5 previous owners, between owners 3 and 5 there was no mileage or service recorded (around 2 years and 30,000 miles). Is this a concern? The car is at Varsity Ford in Ann arbor mich. If anyone wants to take a look at the carfax
(Post 25150316)
Just an FYI - the RS4 forums over here aren't really that active, your questions would get answered much quicker and by a lot more users (that are a lot smarter than me) over on Audizine (https://www.audizine.com/forum/forum...-RS-4-Specific). |
