270/35/19 RE-01Rs and Stasis Motorsports Issues?
Can you guys pls share your experiences with using the 270/35/19 RE-01Rs and Stasis Motorsports suspension kits?
Are these tires to wide to use with a lowered setup?
Was anyone experiencing issues such as the tires rubbing against the fenders on compression?
Many thanks in advance!
They are the perfect tire as long as you stay away from spacers with the Stasis setup...
The only other thing you need to do, is remove the retainer screw and clip for the wheel well liner at the top of wheel arch on the quarter panel. Not really a necessary piece. Also, I think you are talking about 275/30 not 270. Be sure to ask Stasis how to setup suspension for street and track... Enjoy!
Re: They are the perfect tire as long as you stay away from spacers with the Stasis setup...
Thanks, onrails!
Have you experienced any rubbing due to the increased width of the rubber on the 275s?
not sure... Stasis installed it to their standard height.
<center><img src="http://pictureposter.audiworld.com/132032/t-hill4.jpg"></center><p>
pushed to the limit, I've had no problems...
Re: 270/35/19 RE-01Rs and Stasis Motorsports Issues?
Not to be an a$$ but I think it's a 275/30ZR19. I had a set on the 07 and plan on a set for the 08 when I finish killing the stock 255 conti's. But my set up was bars only with no rubbing issues.
