Amsoil AFL 5W 40 European Car Formula Analysis...
<center><img src="http://pictureposter.audiworld.com/111919/amsoil_analy.jpg"></center><p>Ok here is the analysis I just received from Terry at DysonAnalysis. Overall pretty good, just run down by fuel dilution. Great results on the motor breakin. I ran this oil to 2,500 miles and changed it agin with Amsoil.
I wish I had sampled the factory oil but did not, that oil just gave up as indicated by rising oil temps over the final 100 miles before I changed it.
They are different
If you order the Dyson add on from Blackstone, Terry will add his interpretation to the Blackstone lab analysis. If you go to Terry Dyson, you receive his lab's analysis and interpretation. I've compared the two and found the Dyson Labs analysis to be more thorough and accurate. They use different equipment and methods.
BTW, Terry's comments are proprietary. You should not post his complete report on-line.
good analysis
Your engine is wearing in well. But we can see that this engine is pretty rough on oil, with the flashpoint way down and the viscosity reduced to a 30W, indicating fuel dilution. You had more miles on yours when you took this sample than I did, and the wear is a bit lower. I'm about ready to change oil at my 5K service. We'll see how the Elf held up. At that point I'm changing to Motul 0W-40.
CTA4AVANT
30v V6 Discussion
11-09-2006 08:48 PM
CTA4AVANT
10-31-2006 10:57 AM
CGOWA4Q
05-21-2002 06:43 AM
