Anyone had trouble shifting into 1st gear ?
Just recently I started having problems shifting into 1st gear. It doesn't seem to make any difference if the car is warm or cold and it doesn't happen all the time. Maybe 50% or less of the time and it typically happens when I've been sitting at a traffic light in neutral for a minute or two. I go to engage 1st gear and the gate/syncros are basically closed. I have to shift it into 3rd and then back to 1st.
I have just recently passed 10k miles and this has never been an issue up to this point. If I shift into first as I'm slowing to a stop it's fine. It only seems to be a problem when stationary.
Thoughts ?
Thoughts ?
It varies, depending on traffic. Normally 2nd or 3rd down to 1st. When I'm rolling (slowly)
I have no problem shifting into 1st, only when I'm stopped.
When this problem occurs it does affect 2nd as well which is why I mentioned I have to shift into 3rd before going back to 1st.
I do not currently have any trouble shifting from 1st to 2nd once moving.
Smart A$$ :) Actually I was wondering if a slightly stretched clutch cable could cause this.
I have no basis to believe this is the case, just "clutching" at straws!
