RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Anyone hardwire their Valentine One?
Old 01-17-2007, 03:54 PM
Vijay's Avatar
Default Anyone hardwire their Valentine One?
Where did you make connections? How did you route the power cord? where did you mount detector. I have my idea on what to do, but I'm just trying to see if anything else is better or more appealing. Thanks.
Old 01-17-2007, 04:03 PM
star607's Avatar
Default here is a link of ELEVENS hardwire
I followed the pictures and I was finished in 15 minutes.<ul><li><a href="https://forums.audiworld.com/rs4b7/msgs/18680.phtml">https://forums.audiworld.com/rs4b7/msgs/18680.phtml</a</li></ul>
Old 01-17-2007, 04:07 PM
ELEVENS's Avatar
Default Sure Bro - got 10 minutes? That's all the time it takes.
<ul><li><a href="https://forums.audiworld.com/rs4b7/msgs/18650.phtml">CLICKY HERE</a></li></ul>
Old 01-17-2007, 04:31 PM
Vijay's Avatar
Default Are you using your Homelink?
I was actually thinking about slipping the fuse attachment that comes on the power wire into one of the unused fuse slots.
Old 01-17-2007, 05:14 PM
ELEVENS's Avatar
Default Oh yes, all three. But I couldn't find any reference to which wire was switched hot.
I think it's actually easier to go right to the fuse box. I've done many V1-hardwired to homelinks, and feeding the V1 cable through can be tricky, the wires used for the homelink are so tiny that the wire splice doesn't connect well, some cars don't have much room up there for the extra wire bundle, and finally some cars don't have an solid ground connection up there. Especially relevant on a car like mine without sunroof!
But if you decide to try, let us know how it went.
Cheers!
Old 01-18-2007, 07:34 AM
Dr.quattro's Avatar
Default Out of curiosity, does the V1 still effectively work when radar is coming from the rear?
The V1 manual clearly states to have a visible line of sight rearward......I have never located the V1 higher than midway up the windshield, so going that high (next to rearview mirror) seems high.
Old 01-18-2007, 07:36 AM
KMarshall's Avatar
Default Great Write up and pics! Thanks. One question...
... how did you tell which was hot and which was ground when you clipped the flat wire and crimped on the hot to the fuse and negative to the screw?
Thanks!
Old 01-18-2007, 08:09 AM
ELEVENS's Avatar
Default The flat (modular) wire isn't cut. V1 comes with everything needed for hardwiring.
Everything just plugs in nice and neat (except the + and - ).
Cheers
Old 01-18-2007, 08:14 AM
ELEVENS's Avatar
Default If the mirror can see out the back window then V1 should be able to.
BTW - nice pic of your car.
Old 01-18-2007, 11:34 AM
KMarshall's Avatar
Ahh... thanks. I guess I need to find where i put the hard wire kit last year. Thanks!
2003a4MT6
11
05-21-2006 02:41 PM
slimcubby
05-28-2004 11:10 AM
Mike-01A4
09-27-2001 06:21 AM
sid horn
09-25-2001 02:02 PM
Christian J. Long
12-03-1998 08:26 PM
Quick Reply: Anyone hardwire their Valentine One?
