Anyone have the code for our low beam/DRLs or are they the same as the A4?
Re: The high beam is part of the projector HID. The DRL is just DRL, not high beam.
I thought DRL is the std bulb running at a lower brightness level. Well, I know that's the case with my 01 VW. Don't have on my 05 Audi, so just curious here.
Here is some info...
<ul><li><a href="http://webpages.charter.net/parkhill/RS4/DIY/DRL&CLBulbChange.pdf">http://webpages.charter.net/parkhill/RS4/DIY/DRL&CLBulbChange.pdf</a</li></ul>
Many people assumed the DRLs are also high beams because they are big inner lights
If you look at a B7 headlight carefully it's obvious that it's just a regular 1156 bulb used for tails & signals. It looks nothing like a headlight bulb.
1156 bulb:
<img src="http://www.radionic.net/stores/1/images/1156-Clear.jpg">
Headlight bulb (generic, not the B7 one, but you get the idea):
<img src="http://www.casporttouring.com/store/graphics/00000001/philips_vpmain.jpg">
1156 bulb:
Not always headlight bulbs at lower level too.
e.g. #1 - B6 uses front fogs as DRL
e.g. #2 - Certain generations of Chrysler minivans uses turn signals only as DRL
