Anyone know how to remove the ash tray cover without breaking it?--
There was a B5 A4/S4 tech article on removing stuck coins...
I can't find it anymore, but basically you take a stiff notecard and wrap Duct Tape (adhesive side out) around it. Slide the card and tape to where the coins are and then use it to adhere to and remove the coins. I don't know if that will he with your problem, but I thought I would throw it out there anyway.
You could try...Remove shifter trim surround, and unscrew the entire ashtray assembly...
It is only held in by two 10mm hex head screws, you should be able to pull the entire assembly that way, and have your way with it.
Our techs here remove the whole factory radio...
and climate control system. You can then remove the whole ash tray unit to empty out the change. Current record per one of our techs = $7.35 out of one customer ash tray unit.
Change can fall down past the aluminum door and down underneath the ash tray comparment.
DzoNee
A4 (B7 Platform) Discussion
12-24-2015 07:40 AM
shorty1.8tq
01-13-2005 04:11 AM
Blake@NWAutoSalon
02-26-2004 06:49 PM
JustA4
09-12-2002 10:39 AM
