Anyone know if the Stasis SL has a minimum drop from stock or is it adjustable up or down from the
stock perch? That is, is there a max height on an otherwise stock setup with the addition/replacement to the Stasis SL? Where's this thing going to sit at the end of the day at its highest level?
The SL can get much closer to OEM height on the RS4 than the S4 becuase the R was lower to start.
The minimun drop is almost nothing, hardly something they eye could see and then from there you can go as low as you want.
OK. Thanks. I don't really want OEM, just curious of where the base line is
sounds like I need to call and talk it over when I'm ready to order. I'm traveling so much for work, I can't order anything at the moment and it's killing me. I want the SL and Milltek (when Strat gets them in stock).
Where did you end up with it? I'm going to stay stock on the wheels/tires and would like to be able
to put on the 10mm MTM spacers I have without rubbing. I can take the front wheel liner screw out.
I went lower than stock and have no issues - I tried 10mm spacers and
had no rubbing issues either, in fact just ordered a set of track wheels with a 20mm offset which is 9 mm outboard from stock.<ul><li><a href="https://forums.audiworld.com/rs4b7/msgs/74410.phtml">Install pics</a></li></ul>
B56
11-20-2008 10:42 AM
DaveInSaltLake
05-21-2008 12:54 PM
my2000apb MEGABOOST
12-12-2006 08:59 AM
QCRAZY
09-27-2005 03:49 PM
Jason @ Streetwerke
10-22-2003 01:53 PM
