B8 S4 Rims
B8 S4 Rims
Hey guys,
I have a set of B8 S4 OEMs (19x8.5 ET43) and I want to use them as my winter set, and I know the B7 RS4 OEMS (19x9 ET29). My question is, can I mount them and use them for the winter without any problems, or am I going to need something for it to work properly for me.
Thank you!
Thank you!
karsty, thanks for the prompt reply, are spacers readily available to purchase? So if there aren't any spacers, I simply cannot just mount them on? I read spacers are usually for aesthetics, so the wheels fill the wide track of cars and such, but is this for mechanical function and safety as well?
AudiWorld Expert
The hubs are also bigger for the B8 wheels. You might need an adapter too for them.
People use spacers for esthetics and for clearance issues.
You'll need spacers and hubcentric adapter rings. The rings are optional, but definitely make mounting easier. They come in plastic or aluminum, you'll want 67 exterior diameter to 57.1 mm interior diameter.
You'll need bolts, too. Stock length is 27mm, so you'll need at least 47mm bolts with those spacers. Too long (by <10mm) is better than too short.
ECS sells all of this stuff, I have a set of new plastic rings and zinc plated 50mm cone seat bolts that I was going to return but could sell if they'll work for you.
Never Follows
Maybe because he already has a set of wheels and buying spacers/rings would save him $1k?
BTW you would need rings that go from 66.56 to 57.1 and they are not optional. You MUST have them in order to have no vibration.
horizontal8
02-13-2006 02:41 PM
1 Mean TT
09-16-2005 02:59 PM
torontoaudi
06-07-2004 05:04 AM
Justin T
9
01-17-2002 01:25 PM
