Brake noises/feeling on wet or dirty surfaces
When I apply the brakes hard in these conditions, I hear an unpleasant grinding coming from the front brakes and it feels like I'm rolling over a bucket of gravel. Anyone else?
I mentioned this to Audi at my 5k mile maintenance visit, but they indicated that everything was okay. TIA for your help.
Check rotor for signs of scoring....
Its possible that you could've picked up a small piece of debris that has lodged between the pad and the rotor, although it is unlikely.
If the front wheel bearings and suspension show no signs of missing bolts, I can't imagine what the sound could be...so hard to diagnose from behind a keyboard, you know?
Could have fried the pads..that is, heated them enough to transfer some ...
pad materiel onto the rotor. If so, it will wear off over the next few miles with normal driving and light brake applications. The rotors in this case are okay, it's just that you've created a rough surface temporarily from the transfer of pad materiel. What's happened is the resin friction binders have melted from the heat of the high-speed stops. 90-10 is good with some cooling time, maybe 1/4-1/2 mile between applications. If you STOPPED from 90 and did it again, the pads are against the rotor at rest and not a good thing when very hot (1000 F.). But, you probably already know this.
Can't figure in the wet & dirty surface aspect though.
allroadCole
Audi allroad
07-26-2007 09:58 AM
Drollomite Man
23
02-13-2006 06:34 PM
Evan (Vogon)
08-03-2001 05:59 AM
