Can someone tell me where the DRC fluid reservoir is located?
hey Vijay... it's located in the back of the car, underneath the "spare tire" well. If you go underneath the car and remove the plastic cover underneath the spare tire well you'll see 2 reservoirs together.
Hope that helps! |
Originally Posted by KryptoniK
(Post 23769300)
Hope that helps! |
with all the warning systems and annunciators on this car:
seat belts passenger air bag tire pressure the check system, lamps, etc. and on and on wouldn't it be very easy to put a pressure switch on each DRC circuit and set a warning light/check system point if the pressure went low, eg, a leak? that way people could stop worrying about this and just drive the thing... the DRC issue is my only concern with the car...the valve deposits, not so much yet... |
Originally Posted by ArthurPE
(Post 23769369)
