Car update: Complete re-work and modification of the brake system...
I'll start with a small post; the removal of the system but I'm not going to show you the rotors and caliper procedure because I'm sure most of you know and have done so in the past.
I'll concentrate on everything else in the system.
First the removal of the steering column.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSISRa.jpg">
A view of the pedals with no steering column in the way.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-1.jpg">
A view after the pedals were removed.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-9.jpg">
Clutch pedal with its master cylinder (made of plastic).
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-3.jpg">
Brake pedal (made of steel).
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-4.jpg">
Electronic gas pedal (made of plastic) with the three pedals' mounting bracket made of cast aluminium. You can also notice the various relays/switches that are used for both the clutch and brake pedals.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-5.jpg">
From the inside a view of the brakes master cylinder. Located on the right side in this picture just above the "black patch". On its left is the steering wheel column attachment.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-6.jpg">
A view from inside the engine compartment where the master cylinder was located.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-8.jpg">
The master cylinder.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-Brakes-Completere-work-STaSI-7.jpg">
The ex location of the ABS pump/controller.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CompletebrakemodJune2008032.jpg">
The ABS pump.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CompletebrakemodJune2008042.jpg">
The ABS pump.
Jet Jockey/A4 Pilot
06-18-2008 09:29 PM
Jet Jockey/A4 Pilot
06-18-2008 06:49 PM
Jet Jockey/A4 Pilot
Canadian Discussion
06-18-2008 12:16 PM
JacobB
08-30-2007 08:00 PM
