CEL.....
CEL.....
Came on. Dealer said the code was a "random misfire". Anyone experience this? Anything I should be concerned about? The light has not come back on since. TIA.
More here: https://www.audiworld.com/forums/sho....php?t=2746852
Fuel Presure Sensor TSB
Random misfire could be build up as it was done to my car. They cleaned it then of course never fixed the problem. After the third trip it was the TSB on the fuel pressure sensor.
Haven't had a problem since.
You would think… but you'd be wrong.
The carbon buildup on the valves 'issue' is a direct result of the direct injection... there are issues with almost every manufacturer, some more than others. Some have being trying the "walnut shell" method or other chemicals to clean this build-up... with great results.
as for the random misfire faults: as the dealer would do, clear the faults and drive the car.. if the CEL comes on then you'll need some further diag/repair.
i will elaborate more on the chemicals currently used on our porsche vehicles.. and pass the info once available.
_Ryan
_Ryan
91quattro
04-16-2019 10:34 PM
Governor
A6 (C7 Platform) Discussion
09-14-2016 06:08 AM
TEB
10-04-2005 12:06 PM
