CPO'd car in CT w/ odd predelivery items...
Replaced spark plugs and intake manifold before original sale. What gives? This is the 2nd time it has been listed for sale as CPO. Worth pursuing or pass? 19K+ miles since July '06.<ul><li><a href="http://www.carfax.com/cfm/ccc_DisplayHistoryRpt.cfm?partner=ADI_0&vin=WU ARU78E57N900235">carfax</a></li></ul>
My guess would be...
that the dealer was getting a code on the car new, and to try to fix they first put in a set of plugs, because the code said misfire. Then they probably saw that didn't work and figured out the flaps in the manifold were sticking and replaced it. This has happened to a few people here and there, and there is a bulletin on it. I would say if the car is running good and the price is right, get the car. The more important thing is what is the state of the DRC? I would check that, make sure it isn't leaking. If it is, make them replace with the new updated struts and valves from Audi. Other than that these cars are pretty damn solid. In fact I would bet that the DRC is far and away the most problematic issue with the car, and the sticking intake valves would be a very distant second.
Maybe though you can use it as leverage in price? Worth a shot.
All RS4's have new sparkplugs put in at pre-delivery inspection
It's standard operating procedure due to the possiblity of fouled plugs (FSI can do that)
The intake manifold replacement is common too. There are intake motors that failed on most RS4's.
it may have taken a while to CPO( 2/2009)... "The virginity of that engine has been soiled."
<ul><li><a href="http://www.newcountry.com/used_vehicle_details.htm?vehicleId=aa2973fc7f00000 10057255426d09d9f&bhcp=1">http://www.newcountry.com/used_vehicle_details.htm?vehicleId=aa2973fc7f00000 10057255426d09d9f&bhcp=1</a</li></ul>
S929
10-19-2015 01:38 PM
rwkessler
09-26-2013 11:19 AM
Bebee
12-23-2007 04:47 PM
