The cutting/trimming of the doors to save weight as started. Check it out...
First here is the door as it has been for the last month or so. The interior panel had already been removed, so were the speakers and window motor. I forgot to weigh the darn door when fully laden. <b>As is, the door weighs 43 lbs!</b> I'm sure you can easily add another 10 lbs if not more when fully dressed up.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2007.jpg">
Tracing the line where the cutting is going to be done.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-1.jpg">
Close up of the line.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-2.jpg">
The cut out (most of it).
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-3.jpg">
Here are the inner guts of the door.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-4.jpg">
Another angle.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-5.jpg">
An empty door shell.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-6.jpg">
The window frame.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-7.jpg">
After the cleaning but prior to filling down the edges. The sound deadening material (tar like material like in the rest of the car) will be removed tomorrow.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-8.jpg">
The edge after the filling.
<img src="http://i17.photobucket.com/albums/b79/mlab601/CAR-DoorCutting-Trimming-Oct27-2-9.jpg">
<b>So I'm sure you want to know how much weight I saved by this process. Well here are the numbers...
As I stated before the door started at 43 lbs and after the cutting I weighed every part of the door individually and this is the break down...
Door (bottom portion) = 21 lbs
Window frame = 05 lbs
Glass = 05 lbs
Door lock = 02 lbs
TOTAL = 33 lbs
So a savings of 10 lbs! Not too bad.</b>
Another angle.
The window frame.
Glass = 05 lbs
Door lock = 02 lbs
TOTAL = 33 lbs
Jet Jockey/A4 Pilot
Canadian Discussion
19
10-30-2007 09:05 AM
Jet Jockey/A4 Pilot
9
10-29-2007 12:09 PM
Jet Jockey/A4 Pilot
20
10-28-2007 08:23 PM
Jeff Vader - boscoj
01-27-2004 01:45 PM
