RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Do you guys think...
Old 06-04-2006, 11:21 PM
BlkJet's Avatar
Default Do you guys think...
<center><img src="http://pictureposter.audiworld.com/85369/audifront.jpg"></center><p>these 20" HRE's will fit on an RS4? Since I spent a pretty big chunk on them it would be nice.
Old 06-05-2006, 03:13 AM
sparkhill's Avatar
Default Nice wheels! Depending on the width, they should fit, but you may need spacers.
What is the width and offset?
Old 06-05-2006, 06:14 AM
Bob W.'s Avatar
Default only one way to know for sure...
...try putting them on the car.
I think you'd probably need a different tire though, as the overall rolling diameter for an A8 wheel/tire is likely to be larger than for the RS4. If they're not the same, your speedometer/odometer will be off.
Old 06-05-2006, 08:57 AM
Shaun's Avatar
Default I think you're right about the tires...
Proper plus sizing for an A8 would be 255/35R20, whereas the RS4 comes with 255/35R19. That's a significant difference which would raise the ride height .5" as well as affecting the speedo, as you mentioned.
Old 06-05-2006, 09:10 AM
Bob W.'s Avatar
Default if your numbers for the A8 are correct....
...the speedo will be 3.8% too slow if he runs the A8 20"ers on the RS4 (i.e. 62.3mph actual, with an indicated 60mph).
This is according to the applet linked below, which I'm assuming is correct.<ul><li><a href="http://www.miata.net/garage/tirecalc.html">tire size calculator</a></li></ul>
Old 06-05-2006, 09:22 AM
BlkJet's Avatar
Thanks! I'm checkin on that right now.
Old 06-05-2006, 10:07 AM
Der Kimbo's Avatar
Default 20" for the A8 is 275/35-20 (what BlkJet is running)...It will require new tires...
I would do a 275/30-20 4/10" larger in diameter on a 9.5" wheel.
Old 06-05-2006, 10:15 AM
BlkJet's Avatar
Default They're
20 x 40 with a 38" offset. What is it on the rs4?
Old 06-05-2006, 10:20 AM
BlkJet's Avatar
Default HRE just told me
the offsets are totally different, and that I would need a 1" spacer to make it work. Of course they suggested selling them and getting a new set.
Old 06-05-2006, 10:28 AM
Der Kimbo's Avatar
They are 9" width correct?
Quick Reply: Do you guys think...
