Exhaust installed!!!!
I know many people swear by the RS ovals, but I am just a quad tip fan. Looks much racier and purposeful to me. Plus, on the RS4, quad outlets are actually functional.
<img src="http://pictureposter.audiworld.com/561/dsc01586.jpg">
<img src="http://pictureposter.audiworld.com/561/dsc01588.jpg">
<img src="http://pictureposter.audiworld.com/561/dsc01591.jpg">
<img src="http://pictureposter.audiworld.com/561/dsc01579.jpg">
Fully valved and resonated. Sound is just perfect to me. Glad I went with resonated. I can tell that if I didn't there would be a drone under load between 1000-2000rpm. S mode on/off if also MUCH more of a difference than the stock system.
As others have reported, butt dyno says throttle response is better.
Not sure what the diameter of the magnaflow tips are......
These are 80mm. It is Milltek's valved and resonated RS4 system with the tips from Milltek's S5 exhaust. I approached Stratmosphere about building the system in early March after I had seen pics of their S5 exhaust and it occurred to me that these tips could probably be incorporated onto the RS4 system.
I did specify that I wanted the tips staggered to follow the contour of the car. The only issue was whether the valves could be incorporated without have the tips stick out too far. I also like the fact that the tips slant upwards a little more than the stock system, enhancing the racy appearance of the system from the side.
As you an can see, the results are just perfect.
