Follow-up post on the rear wheel "spacer" issue....
...I looked at it a little closer, and I'm not so sure it's a wheel spacer. It appears to be part of the rotor itself. Here are a few pics....the first one shows the embossed part, which in hindsight is probably referring to the min. thickness of the ROTOR, not the spacer (duh):
<img src="http://pictureposter.audiworld.com/414/spacer_thick.jpg">
But it does definitely stick out beyond the surface of the rotor. Here's a (blurry) shot of the front rotor, where it meets the wheel...no protrusion here:
<img src="http://pictureposter.audiworld.com/414/nospacer.jpg">
I know, the wheels are dirty....I'm working on a budget powder-coating program. Oh BTW, someone asked about the battery, so here's a pic of what you see when you lift up the trunk mat:
<img src="http://pictureposter.audiworld.com/414/battery.jpg">
nope..."extended mobility kit"
i.e. air compressor and canister of goo. actually, just having the compressor would have been good enough for 90% of the flats I've had. Good enough to get me to a shop, that is.
the rear roter hub may be the same as B5RS4...
<img src="http://i7.photobucket.com/albums/y298/nogarohiro/051029leftrearpad.jpg">
rear
<img src="http://i7.photobucket.com/albums/y298/nogarohiro/051030RFdisk.jpg">
front
<img src="http://pictureposter.audiworld.com/30545/tirewell-3.jpg">
TMS, tire mobility system
rear
front
27SLEEPER
15
07-05-2007 07:23 AM
