H&R spring kit for 07 RS4
It's been said before and many will say it again...
it's not recommended to change only the springs. A shock/spring combo is the best way to go.
That being said some have done the H&R springs only and seem to be happy. No one knows what will happen after a few 1000 miles are on them though.
I guess you could just get springs and then if something happens to the shocks, just get a new suspension.
depends on if the shocks are compatible with the new springs or not
with some, there won't be a problem changing only springs. although, i wouldn't feel like putting in new springs with used shocks, regardless.
Here's the deal.....
A shock set to a specified set of dampening parameters will ususally have no trouble handling a spring with upto a 20% increase in spring rate. Beyond that, the shock will get stressed.
Now....if you drive on very smooth roads most of the time, probably no need to worry as the shock won't be constantly "working". If you drive on uneven surfaces frequently or drive aggressively a lot, you will most definitely stress the shocks. Of course this could mean that they go in 50,000 miles as opposed to 60,000 and maybe you don't care about that.
Keep in mind also, that the more you lower your ride height, the higher the spring rate needed, by necessity, to prevent the vehicle from bottoming out.
Finally, going to stiffer, lower springs without changing the shocks will almost certainly affect your ride quality to a certain degree.
i was merely pointing it out
certainly not recommending it. the simple point being that you could have oem shocks that match up okay to certain aftermarket springs. not the norm, and i wouldn't even bother trying on a car with more than a few thousand miles.
Contact Rival Motorsport, but they will cost you. Probably not worth it....
STaSIS Alcon's might be the better way to go if you really want to upgrade the stock brakes.
Lenie
12-17-2002 09:24 PM
StazzFla
Performance and Tuning
11-26-2002 03:03 PM
