AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   RS4 (B7 Platform) Discussion (https://www.audiworld.com/forums/rs4-b7-platform-discussion-121/)
-   -   Headlight/Interior Lights Cycling on and off (https://www.audiworld.com/forums/rs4-b7-platform-discussion-121/headlight-interior-lights-cycling-off-2892926/)
micmckee 12-03-2015 06:24 PM
Starting a few days ago I got an error linked to the self adjusting headlights.
It was wet out and I had that error once before and it never came back on after I cycled the power so I didn't think anything of it.
That is until this started happening,
It's all of the lights, headlights, interior, even the NAV colors will adjust. It's like the whole lighting system is cycling off and on. I noticed while this was happening the windshield wipers also pause momentarily. It also happens no matter if the lights are in auto or manually on.
I tried pulling the codes and it was something about the auto levelers not having a baseline essentially. I pulled the diagnostics up and both of the sensors in the wheel well are not sending any info.
I read that you can pull the fuse for that system (fuse 10) and it will kind of put a bandaid on the problem, so I tried that and got no more error code but the lights are still flashing.
Any thoughts of places to start when I try and do some troubleshooting this weekend?
Cheers,
~Mic
micmckee 12-04-2015 07:47 AM
Going to put the fuse back in and pull the exact code while on lunch,
In the meantime I ordered new headlights because I what the heck?
micmckee 12-05-2015 09:43 AM
Okay so VCDS codes
Saturday,05,December,2015,13:42:36:21262
VCDS Version: Release 15.7.2 (x64) Running on Windows 10 x64
Ross-Tech: Home
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Control Module Part Number: 4F0 910 357 F HW: 4F0 907 357 F
Component and/or Version: AFS 1 H01 0020
Software Coding: 0000019
Work Shop Code: WSC 06335 000 00000
Additional Info: 8E0941329A AFS-Modul links H03 0010 8E0941329A AFS-Modul rechtsH03 0010
VCID: 2959EEE280AA2C761C-807C
2 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Kind of stumped D:
micmckee 12-05-2015 10:02 AM
I'm in group 2 of measuring blocks and it says front and rear sensors are undefined not sure what that's about
micmckee 12-05-2015 10:03 AM
If I go to basic settings it just continues to run group 1 no error no completion,
I've let it run for a few minutes now
micmckee 12-05-2015 10:11 AM
Went to group 11 and i can make front/rear values change when i move the control arm
micmckee 12-05-2015 10:26 AM
OKay so I put everything back and was going to take it to advance to have the battery tested (my volt meter isn't very accurate) and after I started the car these things happened.
Passenger window would crawl up a few inches and stop, rinse and repeat till it was all the way up. Then I tried the rear window, and it stopped and wouldn't move anymore.
Radio shut off
Lights shut off completely and wouldn't turn back on
Car was still running at this point.
Shut off the car and am pulling codes now, but everything went back to normal D:
micmckee 12-05-2015 10:35 AM
Okay got it to recreate the errors and electronics cutting out, here's what I mean by the windows cutting out somtimes.
(YT: Windows stopping)Click to play video inline.
Here are the codes that rang up, new one is the last one and it has a headlight with an ! in the middle of it on the dash.
Saturday,05,December,2015,14:33:01:21262
Ross-Tech: Home
Address 55: Headlight Range Labels: 4F0-910-357.LBL
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
micmckee 12-05-2015 03:38 PM
Battery is officially fine....
So no leads haha
