hmmmmm?
hmmmmm?
what do you guys make of this<ul><li><a href="http://www.rs246.com/index.php?name=PNphpBB2&file=viewtopic&t=7 3889&sid=7daf924432873bea9b6b121be36cc4c2">htt p://www.rs246.com/index.php?name=PNphpBB2&file=viewtopic&t=7 3889&sid=7daf924432873bea9b6b121be36cc4c
I don't believe it. Here's why.
The gains appear to be fairly consistent across the entire rev range looking at the torque curve.
If the manifold was a flow restriction, you'd see very little gain on the low end increasing to more gain on the top end as airflow increases and the manifold became a bottleneck.
The fact that the before and after shows a near constant delta between 2500 RPM and 8000 RPM leads me to believe there is some other effect at play...different intake temps, different timing, different A/F ratio, etc etc etc.
pdf says it's corrected hp and torque. He said no change to ECU/AFR.
Porting the manifold is an old hotrod trick and 7% is not outside the realm of possibility for an engine that's all about volumetric efficiency.
Check out this info......
Intake manifold design is apparently already optimized. It seems reasonable that in designing an engine like the RS4, such a fairly simple measure wouldn't be overlooked.<ul><li><a href="https://forums.audiworld.com/a5/msgs/14363.phtml">RS4 engine design</a></li></ul>
You're not seeing things here.
Correction has nothing to do with how heatsoaked the engine is. You can do multiple pulls on an RS4 and I can almost guarantee that each subsequent pull will give you less power than the last. It's very reasonable to think that a 20 hp swing is possible with no changes done to the car, ECU, or conditions.
The RS4 is a long ways from an old hotrod. Hundreds of hours of computer work doesn't leave horsepower on the table that can be freed up by some bloke with a 6-pack and a dremel tool.
