I need some tips for utilizing the SD card capability, I know nothing. Links please.
Just put MP3s on an SD card. Unless...
You can use folders too, but not more than 1 folder deep I believe. And, it will only recognize 512 songs on each card.
They have to be *straight MP3s*.... no iTunes Music Store purchases or songs downloaded from the new Napster, etc. There's a program for Windows called Tunebite that can convert away from those protected formats.
You can also set iTunes to import files as MP3s and then burn a couple to a CD-RW, re-import them, then erase that CD-RW.... repeat.
This should work.
Buy a few cards from Newegg and you are set.<ul><li><a href="http://www.officemax.com/max/solutions/product/prodBlock.jsp?BV_UseBVCookie=yes&prodBlockOID= 1611445710&expansionOID=-536879947">http://www.officemax.com/max/solutions/product/prodBlock.jsp?BV_UseBVCookie=yes&prodBlockOID
Re:"Someone had a cheap USB writer/reader for the cards?" You can make a profit buying some...
<a href="http://dealnews.com/categories/Computer/Storage/Flash-Memory-Cards/108.html">try this</a>
you can usually find 1GB cards with readers built in or included for under $20
Evil, here are a couple of threads on SD Cards + MP3s
You can store MP3s in folders more than 1 deep. I store mine by artist then album. See the first thread below for info on creating playlists.
<a href="https://forums.audiworld.com/rs4b7/msgs/29558.phtml">https://forums.audiworld.com/rs4b7/msgs/29558.phtml</a>
<a href="https://forums.audiworld.com/rs4b7/msgs/27967.phtml">https://forums.audiworld.com/rs4b7/msgs/27967.phtml</a>
2? Uses - MP3's and Nav Display Screen Captures Tips 1-Size Matters, 2-Bigger is Not Always Better
for me it's song capacity vs play effort..
I would suggest getting 2GB cards and using sub-direcotrys and/or playlists to get the most use from the cards.
<a href="http://www.navplus.us/forum/viewtopic.php?t=746"> Song Order/PlayLists</a>
<a href="http://www.navplus.us/forum/viewtopic.php?t=1892"> Capture NAV screenshots</a>
