Installed JHM shifter last night. Will it fall out of adjustment?
It took a while to get it right as there isn't much range of adjustment, if at all. I torqued down the rod bolt as much as I could without stripping it but I'm wondering if that bolt will ever loosen up. It seems like there could be more of a failsafe design than that. I drove it around last night on the back roads pretty aggressively and it feels great, very solid and snick snick feeling. Someone here said 'rifle bolt action' which is pretty indicative of how it feels.
I'm having thoughts of that bolt letting go and getting stuck in one gear during rush hour traffic on the freeway. OH GAWD WHAT ANXIETY...!!!
If anybody has had problems with it please speak up.
Re: Installed JHM shifter last night. Will it fall out of adjustment?
Use Loctite, it is specifically for fasteners when a lock nut is NOT used. Get it at a good hardware store, put 1 or 2 drops on the thread at the nut.
Re: I noticed there was blue loctite on the stabilizer rod bolt but not on the shift rod bolt.
It would be kinda tough to add loctite on the shift rod bolt since it takes a while to find the sweet spot.
I went back and used loctite for piece of mind. Noticed on one of the videos
specifically the one where it shows him using an angle gauge to adjust the shifter to a 6 speed tranny the the shifter shaft is completely straight. My JHM shifter has a bend in it toward the driver so I didn't use the angle gauge for that adjustment but rather just the lateral adjustment.
B56
09-19-2008 04:27 AM
shawfm
08-28-2008 08:48 AM
ATH
19
08-14-2004 04:57 AM
Chuck-S4
02-27-2004 05:40 AM
blk18tq
12-23-2001 10:00 AM
