Installing Motorsports and need input.
Alright, I am about to install some Ohlins on the car and was wondering if anyone has had a headlight level issue after the car was lowered.
I ask this because when I did the PSS9's on the B6, the headlights pointed up a bit too much so I took it to the dealer to have it corrected and it really didn't do the trick.
I think it's pretty much a given when lowering any car that you may have to
adjust the aim of the lights, be it up or down. On my B5 I had to have them lowered, and on my B7 I had them raised.
Part of the issue aside from the obvious change in ride height is that the rake angle is usually adjusted, even if only slightly.
Get it VAG'd. They have a machine that does it so much better than you can eyeball.
You can tweak it forever but in my own experience, it comes out better and with less hassle if you have them do it.
